Samrsnow
AKA glue sniffer
- Metairie Louisiana
Looking for a pullstart backplate and pull starter or roto backplate in working order.
Problem is that it is that the starter shaft and backplate seem to be proprietary. The shaft end is smooth on two sides only, every other one I’ve seen is hex style. I’m not sure if there is another shaft that could be the same size. I could be wrong about the backplate tooThere are only 2 different sizes of pullstart or rotostart. Measuring across the screw fixings they are either 27mm or 32mm where they mount to the motor back plate.
