Spur gear
Jason9283
Where can you get a 49t spur gear for a savage 25?
ebay is usually your best bet.
If I'm not mistaken the savage X uses the same spur gear.
Here's an example
Most of the time they will be shipped from China so you'll have to be patient for it to arrive.
Have a look on aliexpress too
Depends on the CB you have. Only certain ratios fit mechanically. A smaller spur means you have to move the engine closer to the spur and if your engine is at the end of the slots, then you have to get a larger bell. I think 16 or 17 is as low as you can go with a 47T spur.
