Thanks man! Can you send me a link to which would be the best clutch for me to runspring for some alloy clutch shoes also. 1.1 springs will work fine.... and tighten down the slipper nut all the way down tight, and run it, if it hits too hard you can always loosen the slipper nut by 1/4 a turn....
I can see that the dogbones in the center are moving, so it's either the side dogbones, hexes, or the diff
I finally got to take my truck apart and I found the culprit it was the bever gear
So they make a bullet proof diff, do they make a bullet proof pinion toooo?
Anyone ever shot one with a bullet to see if that's true?
