Savage anti-squat
Mr.Marmot
Hi. Any ideas on how to give more anti-squat to a Savage?
I have a 29cc gas engine on the rear of the rc4me savage xl, using the stiffest shock spring/collar position I could manage. I feel it is stiff enough for handling the car after acceleration, but I need more anti-squat for being able to pull the trigger harder.
I was wondering if anyone knew about some aftermarket hinge pin plates that could give more anti-squat or some other way.
Example from the hpi baja:
https://www.ddmracing.com/PhatDad-RC-Anti-Squat-Brace-For-HPI-Baja-5B-5T-5SC-SP510T
stiffer springs, heavier oil, maybe you could even double spring with a heavy and light spring ' used to be able to use traxxas tmaxx shock springs( they are only about a 1/3 as long as an HPI shock spring) with Hpi springs and shocks for a "dual rate" type of absorber
