Chris_sava
- Neath Port Talbot
I'll add some corresponding pictures/images of the jobs in hand listed below, once I work out how to add them.
R/C Car work/jobs to be carried out.
Hot Bodies GTX2 #1
Swap out the atom3 receiver for the eTronix receiver from the GT, and get the vehicle running correctly (balance throttle linkage).
Fit spot lights and/or tail lights.
Detail tyre sidewalls.
Hot Bodies GTX2 #2
Fit aluminium rear hub carriers
Fit aluminium centre spool/diff carrier.
Fit aluminium front 'C' hub carriers.
Replace throttle linkage with the correct components.
Replace LRP receiver with eTronix receiver.
Replace 1600mah hump pack for 2500mah hump pack.
Replace plastic diff cases with aluminium type x2.
Hot Bodies GT
Fit aluminium centre spool/diff carrier, maybe refit centre spool
Replace plastic diff cases with aluminium type x2/3*
Swap out the eTronix receiver and replace it with the atom3 receiver from the 1st GTX2.
Savage SS X 4.6
Replace reverse servo for a less powerful one.
Adjust the gearbox to shift through all gears.
Replace all suspension shockabsorbers with new units.
Savage bitsa.
Build up as far as possible with parts from the parts bin and then assess what further parts are required to complete the build.
Kyosho Giga Crusher D/F
Locate two suitable replacement fuel tanks.
Locate missing exhaust tail trim
Fit 3ch KR331 kyosho receiver.
Kyosho Hi Rider Corvette.
Replace existing tx/rx setup with the LRP tx/rx setup from the 2nd GTX2. Possibly look into replacement of the mechanical speed controller for a period correct ESC and brushed motor.
*depends if a centre diff remains*
Hot Bodies GTX2 #1
Hot Bodies GTX2 #2
Hot Bodies GT
Savage SS X 4.6
Savage bitsa.
