Hpi savage x 4.6 spur gear upgrade
Zane Lewis
Hey, I have ordered a metal 49T spur gear and I was wondering if the stock slipper clutch would work with it or would I have to order a different one
It should work just fine as long as you ordered the one for your model of savage. Theres two different styles as far as I know. The older one that has the gear and then just the spring and nut, and then the newer one which has the slipper plates on both sides of the gear. Post the link to what you bought
It sounds good man. Make sure you put an air filter on that thing before you take it outside lol
I will lol going to order it sometime this week. I have a problem now was trying to take the engine out so that I can clean some stuff and I’ve got the dang stinger stuck it won’t come out
Loosen up that small black set screw and it should wiggle out. Make sure you use the right size wrench, those little guys like to strip out very easily
Thanks that worked. Man I tell you what this engine is really dirty! Glad I went ahead and pulled it out
http://www.motorsaverfilters.com/savage.htm
Lots of people swear by that brand.... I find most any 1/8 scale big block type will work well if you keep it clean....
https://www.ebay.com/itm/Horizon-1-...796882?hash=item1ee0d0c3d2:g:co0AAOSwJ-pa-F~f
https://www.ebay.com/itm/HPI-Racing...501010&hash=item1ccf858ef3:g:EYQAAOSwCrtcueBq
if you have the stock HPI housing assembly you can just buy replacement foams and oil them up with K&N airfilter oil
Thanks for the recommendation
Thanks Jam, been looking for replacement filters also lol just bought me one of those motor saver ones, they look saweeeet
Can I ask which metal spur gear I should order for my Savage 4.6 gt-6 V2 as my plastic gear shredded ? Please post a link if allowed.
Hi Gents does anyone know where I can get the HPI Savage X 4.6 GEN3 Slipper Unit? Everywhere I look was out of stock. Also what else would I need to complete the assembly. Lock Nutes, Spring, wassers?
Thanks for the reply, Seanthemechanic. But the link is to the original plastic Spear gear design, which we all know is not reliable. The moment the plastic starts deforming, it reduces friction and increases slippage, consequently generating heat to the point where the gear's functionality diminishes. The one I'm looking for is Robinson Racing: "HPI Savage X 4.6 GEN3 Slipper Unit" http://www.robinsonracing.com/catalog/savage46.html
