Gazzman
- Haywards Heath, Untied Kingdom
Well folks build No.9 is near to completion, This build is a stock Savage 25 made mainly from my parts bin. It has a new unused set of GT wheels & tyres from an SS kit I picked up awhile ago. The mill is a new Force 4.6 with Roto start, not yet started, running a set of FeeTech 35kg servos with a FlySky GR3E receiver powered by a 1600Mah battery hump with external charge lead. 29/9T bulletproof diffs running through std 9mm output drives mated to 15/47T clutch spur setup. The exhaust is a Tsais twin chamber Stinger pipe. It has a twin fibreglass brake disc setup aswell.
Need a few parts to complete this build including, a new air filter, bodyshell, front gearbox output cup & a new engine mount as the one fitted has a stripped bolt hole . All parts ordered and in the post, so should be complete by next weekend. May use a K5.9 mill that I've just rebuilt instead of the F4.6 as just want to run this and really can't be arsed with the fluff of breaking in a new mill. The bodyshell will be a GT2 shell as cheap and available.
Future upgrades will probably included Savage X TVPs, bulkheads & diff housings.
