TunaBait
Sand Basher
- Seaside Oregon
Heres a little trick I have done for a long time.
Most ppl don't know but most stock pull start line is a braided Dacron line (The same they use for pro kites). But what comes stock is like a 50# test. What you can do is get 110# test and replace it after the stock breaks. Note you cant have the line as long as you could with the 50# test but you still can get at least 2 1/2 - 3 feet of line on the spool depending what type it is. Yes the 110# test will still break but will last you much longer then the 50# test. And if you live at the beach like I do a stock line don't last long as the sand chews it up. I would not go any higher in test as it gets to big unless you want a like a foot of line comming out.
And for $15-20 bucks you will have a lifetime supply here is a link.
http://www.windpowersports.com/accessories/line/dacron-line.html
don't know if anyone has posted this before but thought I would. Sticky somewhere if you like .
Hope this helps someone...
Tuna Bait
Tuna Bait
